Fuel injectors not firing on 90 240
Old 04-12-2006, 03:04 AM
J Taylor's Avatar
Default Fuel injectors not firing on 90 240
I recently picked up a 90 volvo 240 from a friend's parents. It's a one owner car and very very clean and straight but has been sitting for about 6 years. There are a couple of problems and the car won't crank. I had to basically hotwire the fuel pump. It's getting plenty of fuel to the rail but the injectors aren't firing. I pulled the rail and turned it over to confirm this. I then hooked a power directly to an injector and it fired perfect so I know it's not the injectors. My first thought is a bad ECU but I'm hoping to get some input before I replace it. If anyone has any ideas I would appreciate it.
Thanks,
JT
Old 04-12-2006, 04:24 AM
Default RE: Fuel injectors not firing on 90 240
Might be the fuel injection relay.
Old 04-12-2006, 09:31 PM
Could also be a speed sensor if it has one. If it doesn't then the pickup in the Dist. might be bad.
pinegrovedave
04-21-2014 01:44 PM
Vmax
04-07-2014 07:42 PM
eboknight
03-22-2009 10:30 PM
pikey
05-10-2007 01:34 PM
sambagis
01-24-2007 09:03 PM
Quick Reply: Fuel injectors not firing on 90 240
