sea foam ????? ever tried this method ????
Old 03-25-2007, 07:07 AM
jguerra3235's Avatar
Default sea foam ????? ever tried this method ????
Check out this link.
http://forums.turbobricks.com/showthread.php?t=35053
Putting water into a cylinder scares me. But a lot of people swear by this seafoam method. Has anyone here ever done this? How did it work? What are your thoughts?
Old 03-25-2007, 10:13 AM
Default RE: sea foam ????? ever tried this method ????
I've never done it the way it was described on turbobricks but I have used seafoam with great results. A few days after you do this process remove a spark plug and look in the cylinder, things will be CLEAN!! You're not going to hurt anything by putting small amounts of water into the engine while it's running, all it does is help to loosen the carbon that is coating the top of the piston and the valves, then the seafoam will do the rest. Either way you should come out fine. I really need to add this to the list of things to do next Saturday, thanks for reminding me.
Old 03-25-2007, 10:20 AM
S70driver's Avatar
Just read the can man. That is all you have to do.
Newport_j
01-06-2012 10:36 PM
Newport_j
06-17-2011 03:10 PM
LobsterThief
05-29-2010 01:35 PM
Volgrrr
02-11-2008 08:43 PM
Volgrrr
11-10-2006 01:30 AM
Quick Reply: sea foam ????? ever tried this method ????
