Sea foam in oil
Old Dec 26, 2011 | 02:10 PM
Newport_j's Avatar
Default Sea foam in oil
I am uncertain/afraid to use sea foam. I am okay about putting it in my gas tank. I just am uncertain about putting in my oil which is a synthetic. Is this okay? How soon must I change my oil after I put sea foam in? Right away or after some driving?
Newport_j
Old Dec 26, 2011 | 09:29 PM
AutoNaut's Avatar
If your engine is pretty clean than it probably is not necessary to run Seafoam or any additive. However, it is safe. I have used it several times in my V50 T5. When I bought my car used, the oil was like sludge. Right after an oil change the oil would turn dark. I started running Seafoam about 1K miles prior to the next 3 oil changes and it cleaned up nicely. I still dump some in once in a while prior to an oil change.
Stan
Old Dec 28, 2011 | 01:06 AM
Hudini's Avatar
500 to 1000 miles is good, it thins the oil and cleans the built up gunk.
Another trick is auto trans fluid in the engine oil. Just a pint or less, do not to overfill the crankcase.
Old Dec 28, 2011 | 08:55 AM
AutoNaut's Avatar
Trans fluid? I had not heard of that before. Is is safe for O2 sensors?
Old Dec 30, 2011 | 06:36 AM
Hudini's Avatar
Don't know about O2 sensors. Prolly not since this trick has been around since carb days. It's old school for sure. It's good for sticky lifters in a pushrod engine, for instance.
Old Dec 30, 2011 | 10:10 PM
AutoNaut's Avatar
Ok, I do remember that.
Old Jan 5, 2012 | 08:55 PM
jfisk60903's Avatar
A lot of you have hinted about Seafoam and it's effect on your engine internals. Seafoam can be used at every oil change and made resident for the entire service duration. I swear by the stuff, it can work miracles around turbos with coking problems, help reduce sludge buildup and maintains a clean sump pick up screen without doing any internal damage at all. read the label guys, it's fully approved under DOT lubrication standards and no I don't work for them...lol
Old Jan 5, 2012 | 10:21 PM
AutoNaut's Avatar
I am aware of the label instructions. I am also aware of the Volvo owners manual which states, "Volvo does not recommend the use of oil additives." This statement, however, doesn't seem to stop the dealers from using additives. I use oil additives as little as possible and use good oil, Mobil 1 Synthetic or other full synthetic.
Stan
Old Jan 6, 2012 | 07:34 PM
jfisk60903's Avatar
AutoNaut every owners manual on the planet says don't use additives, yet you visit your local service department and one of the 1st things they recommend is a fuel system or crankcase additive, But their particular brand. It wasn't 5 years ago that Ford didn't recommend synthetics for goodness sake. Now it's spec oil on their HO plants as well as GM's. I don't replace a quart with a can of Seafoam, you mix in small recommended amounts similar to Gumout additives. 1.5 oz per oil change in a 4.5 too 5 quart system. Gotta read the directions and do it right, if you do you won't have anything but positive results. Happy Motoring Bama
Old Jan 6, 2012 | 10:36 PM
AutoNaut's Avatar
Sorry jfisk60903, I wasn't looking to start anything here.
Newport_j
Jun 17, 2011 03:10 PM
LobsterThief
May 29, 2010 01:35 PM
Volgrrr
Feb 11, 2008 08:43 PM
jguerra3235
Mar 25, 2007 10:20 AM
Volgrrr
Nov 10, 2006 01:30 AM
