sea foam ????? ever tried this method ????
Old Mar 25, 2007 | 07:07 AM
jguerra3235's Avatar
Default sea foam ????? ever tried this method ????
Check out this link.
http://forums.turbobricks.com/showthread.php?t=35053
Putting water into a cylinder scares me. But a lot of people swear by this seafoam method. Has anyone here ever done this? How did it work? What are your thoughts?
Old Mar 25, 2007 | 10:13 AM
JetTech's Avatar
Default RE: sea foam ????? ever tried this method ????
I've never done it the way it was described on turbobricks but I have used seafoam with great results. A few days after you do this process remove a spark plug and look in the cylinder, things will be CLEAN!! You're not going to hurt anything by putting small amounts of water into the engine while it's running, all it does is help to loosen the carbon that is coating the top of the piston and the valves, then the seafoam will do the rest. Either way you should come out fine. I really need to add this to the list of things to do next Saturday, thanks for reminding me.
Old Mar 25, 2007 | 10:20 AM
S70driver's Avatar
Just read the can man. That is all you have to do.
Newport_j
Jan 6, 2012 10:36 PM
Newport_j
Jun 17, 2011 03:10 PM
LobsterThief
May 29, 2010 01:35 PM
Volgrrr
Feb 11, 2008 08:43 PM
Volgrrr
Nov 10, 2006 01:30 AM
