ignition timing
Old 05-23-2007, 05:11 AM
pravin's Avatar
Default ignition timing
Greetingsto all.
i need some help setting the ignition timing on my 1984 240dl (1986cc).
Does anyone know the correct contact breaker gap and the strobe ignition timing for this car? im using 97 RON unleaded fuel.
Any help greatly appreciated..
Old 05-24-2007, 10:50 AM
Default RE: ignition timing
I have no experience with your model car, mine is a 91 240 which is quite a bit different. I did however look up the specs on ALLDATA and it said 12' BTDC timing with the vacuum line off of the distributor. Also it says your car has a hall effect ditributor which means you don't have any points. Hopefully this helps a little and at least gets you on the right track.
Old 05-25-2007, 01:24 AM
pravin's Avatar
Thanks for the reply.
Actually the car does have a conventional dizzy with contact points. Just changed it 2 days ago. At the moment i'm trying to locate the engine code on the block..seems to have disappeared. There are not many of this particular model volvo in this country, so far i've only seen 1 other, that was a long time ago. Most240'sare the 2.4L 240GL..I'l post again when i find the code;.. if i find the code, rather.
dodgerkcj
07-02-2018 11:41 AM
Ricardito
08-14-2012 08:29 PM
roytoronto
04-26-2009 10:59 AM
roytoronto
04-05-2009 09:04 AM
Quick Reply: ignition timing
