wet or dry? opinions.
Old May 25, 2007 | 12:41 AM
VolvoDriver's Avatar
Default wet or dry? opinions.
When doing the timing belt and replacing the sprocket seals, is it necessary to drain engineoil?
Old May 25, 2007 | 02:05 AM
tedv's Avatar
Default RE: wet or dry? opinions.
Necessary? No...
Old May 25, 2007 | 09:59 AM
...but probably a good idea? wouldn't the oil spill out???
Old May 25, 2007 | 10:36 AM
tedv's Avatar
For the timing belt change, no, it'd not spill out... And while I am not sure about which "sproket seals" you are reffering to, the oil stays in the oil pan and shouldn't spill out if any work is done above its level. But, since you are at it and getting dirty, if it at all needs the change, well, then do it!
Old May 25, 2007 | 10:51 AM
thanks for the reply,
I speak of the engine oil seals, cam, layshaft, crank.
klart
Jun 7, 2011 06:53 AM
rspi
Jun 6, 2011 04:44 PM
jstecher2010
Jan 19, 2010 03:12 PM
livelychick
May 19, 2009 09:54 PM
Beardog
Oct 9, 2007 02:26 AM
