940 fails when get 4.000 rpm
Old 09-14-2009, 04:15 PM
Fernando Cabezas's Avatar
Default 940 fails when get 4.000 rpm
The engine of my 940 turbo fails when I try to speed it fast, it get 4000 rpm and it seems to be that there is no fuel, I have changed the distribuitor and rotor, fuel filter, cheched the fuel pump presure, but still I have the problem, it tipically happens when you try to get speed when you get the highway.
I would appreciate any help on this matter
Old 09-14-2009, 05:55 PM
tedv's Avatar
"Seems there is no fuel", but you have a high speed engine misfire under load which is caused by fuel or by ignition, spark. You have looked at all the fuel issues, now look at the spark: plugs, wires, etc. Wires may be the cause, especially in wet conditions, as well as the coil, as well as a cracked dist cap. Or the power stage amp... Sorry, it's a lot but it goes fast once you get into it.
Old 09-14-2009, 07:55 PM
Thanks I will check the wires tomorrow
Old 09-16-2009, 04:33 PM
I have checked the spark plugs and wires , everything is OK, I have also changed the amplifier module and the crankshaft position sensor is new
Old 09-17-2009, 07:42 AM
adub96's Avatar
Dirty injectors. Try to run some fuel system cleaner through, or just buy some new injectors. i have seen this occur far too many times.
Old 09-19-2009, 06:47 AM
I have cleaned injectors, I am thinking in the pressure regulator , because i have checked only the fuel pump pressire but not the pressure in the system, someone knows how it work?
Old 09-20-2009, 04:07 AM
Typhoon's Avatar
Check the intake hose from the air filter is not collapsing.
Regards, Andrew.
Old 09-20-2009, 08:20 AM
By chance was the rear main seal just replaced?
Old 09-21-2009, 09:00 AM
Default Problem solved
Thanks typhoon, it was the intake hose collapsed. I have used a pair of clamp around the hose to avoid it collapse.
Best Regards and thanks again for the help
Old 09-21-2009, 07:42 PM
Glad you found it.
Old 09-22-2009, 05:25 AM
Typhoon's Avatar
Cool. Easy fix! I only know about this problem because a good friend of mine with a Volvo spent months chasing the same problem.
Regards, Andrew.
MyCorvette
09-02-2014 09:37 AM
Rapid Dog
11-08-2010 03:34 PM
yellowtr6
04-27-2005 01:36 AM
Quick Reply: 940 fails when get 4.000 rpm
