volvo 940 no acceleration when cold
My 940 wagon ('93, automatic transmission) recently started to have quirks. When car is cold and I am driving on a slight hill/trying to merge into hwy, the car won't accelerate beyond 20mph-25mph. The tach freezes around 2000 RPM and does not climb any higher.
When I floor the gas pedal, the car even slows down instead of switching into lower gear and accelerating (sometimes the engine seems to eventually overcome this weird behavior, then the RPM would surge to 3-4k and car would start accelerate). This is ok in a city, but is really scary when trying to merge into hwy. When car warms up, things get back to normal, so the issue seems to be intermittent.. Any ideas/suggestions would be appreciated.
Check the fuel pressure. My '92 940 (Regina system) had similar symptoms... bogging down on inclines...sudden acceleration. Testing the fuel pressure showed an erratic amount of pressure (putting the adapter on the test valve ain't easy). Putting in a new in tank fuel pump cured the problem.
The car was recently out of gas and then it indeed behaved very erratically. The issue that I have is not like this, moreover it does not depend on the incline (I checked just today): the car just cannot bypass the 2000 RPM even when I am going down the hill and flooring the gas.
Could this behavior be potentially caused by the holes/leaks in the exhaust pipe between engine and Oxygen sensor? The car was recently in an "accident" when it slowly ran over the road sign pole, bending it so it was stuck under the car. I didn't see any damages but I guess it could have potentially damaged the exhaust system. What is the best way to check for leaks? (smog test is due only in 1 year, so it's not an option)
the coolant temp sensor normally isn't something a shop would check when replacing a radiator. they'd check and/or replace the thermostat. maybe the sensor in the radiator that controls the aux cooling fan. but not the coolant temp sensor, thats in the block, and is wired to the fuel injection ECU and ignition ICU.
Sorry, I had a hard time attaching image here. May be this time it works better. Do you see the image below?
volvorecycle
07-22-2015 07:44 PM
VolvoJimmy960
06-03-2007 10:20 AM
