engine run on high speed without push gas pedal
RE: engine run on high speed without push gas pedal
Hi,
here is more info about my 1997 960. I tried to start it tonight and it started, but when I waited for a while on park or tried to put on gear, the engine speed go up and it was loud without pushing the padel. then, I see the white smoke came out of the exhust pipe. I remember that I had to put a little more coolant a few times this year. now, I think it might be water goes in to the engine. My check engine light has been on for about half year. at beginning I went to the dealer and was instructed to change C. converter, I though it was too expensive for OEM part so I put a off market one which worked for a while and then the check engine light came back on. I had it checked by the dealer. it seems that the off market C. converter may not take care of the check engine light. so, I just let it on since it didn't seem to have anything wrong. Now, the car is not drivable.
