94 turbo cylinder head interchange
Old 10-02-2015, 11:23 AM
Cj0312's Avatar
Default 94 turbo cylinder head interchange
I'm looking at a 94 turbo that has bent exhaust valves from a broken timing belt. From what I can tell the belt went and they just got it replaced without checking the head and then realized there's damage. The junkyard near me has a few non turbo 850s as well as a low pressure turbo 99 s70. Are either of these suitable to pull either the exhaust valves or the whole head to use on the 94 or do I need valves from a turbo 850? Thanks in advance guys.
Old 10-03-2015, 10:12 PM
Pretty sure the exhaust valves are the same across those models but why would you just not buy new valves to begin with or shop for a replacement head from a 94-97 850 turbo?
FCP Euro sells Osvat replacement valves at $12 per. You still need to properly lap the valves in, and in my mind doing that with new valves will ensure a better fit or you may risk a burnt valve prematurely.
If you want to find a replacement head, you can search most yards using car-parts.com
Old 10-13-2015, 10:15 AM
mudpie's Avatar
I was under the impression that the turbo had sodium filled exhaust valves. Even if they were the same though, the point is valid...why waste the time to pull a used valve?
Old 10-13-2015, 10:51 AM
Cj0312's Avatar
I just figured I'd be better off with a whole spare head to work with. Like I said they replaced the belt after a break and only noticed a problem after firing it back up so there may be more than just the bent valves. I had no idea I could buy individual valves so thanks mt6127 that's why I came here and asked.
Carrots
02-14-2017 10:18 AM
GFL63
02-13-2017 01:42 PM
GFL63
11-01-2011 07:53 PM
Brian Mc
05-20-2009 08:56 PM
GLTLOVER
03-28-2007 01:10 AM
Quick Reply: 94 turbo cylinder head interchange
