boost gauge not working
Old 01-13-2011, 11:54 PM
chuck_norris's Avatar
Default boost gauge not working
Hey guy,
Just noticed while driving today, my boost gauge is stuck right in the middle, even under heavy acceleration. Didn't notice any loss in power and when I turned it off, it stayed there in the middle.
From what I understand and remember, the gauge should go to half way in the middle when really pushing the car and goes right to the bottom when the car is turned off.
My question is if this would be a hole in a vacuum hose somewhere or is the gauge itself just broken?
Thanks for any help
Old 01-14-2011, 12:34 AM
ibified's Avatar
could be eother one. Check on the vacuum tree to see if the hose came off first. If that's good, then pull out the instrument panel and see if it came off the back of that. if it's still attached, you most likely have a hole in the line somewhere.
Old 01-14-2011, 12:39 AM
Mad Matt's Avatar
Sounds like the gauge lost its connection to the vacuum source somewhere along the line. Have you checked it's mounting location on the vacuum tree in the engine bay? It's right under the throttle body cover. You'll see a few vacuum lines coming out of it. The boost gauge line (if it's the same as my '97 850R) is the yellowish one. There is also a connection that is clipped to the top of the hood release. It has the yellow line going into a larger black line. See if the connection at either one of those two spots are broken or loose. I'll see if I can find pictures of what I'm talking about....
Old 01-14-2011, 11:25 PM
Sticky option:
27 Turbo Boost Gauge Not Working - Cruise Control Not Working
https://volvoforums.com/forum/showthread.php?t=29883
Old 01-17-2011, 04:40 AM
Thanks for the suggestions guys. I'll most likely have a chance to tackle this problem tomorrow morning. The turbo is definitely still working, had a few minutes tonight to take her on a short highway run and acceleration was the same.
I hope it is one of the vacuum lines under the throttle body or even under the battery as I got from the sticky option (thanks rspi). I really don't want to take the dash apart.
Will post if and when I figure it out.
Thanks.
rspi
05-15-2014 07:36 AM
559s40
07-13-2012 10:50 PM
ibified
05-26-2011 01:03 AM
turbo940v
09-03-2010 08:36 AM
Quick Reply: boost gauge not working
