Generator light blinking when car is off
Does the light go off when you start the car??? I'd look into one of two things - the ignition switch is shorting or the Alternator's voltage regulator (ie the diodes) have shorted creating a circuit path from the battery back to dashboard... Try wiggling the key a bit when turning off the car to see if that stops it. If you have a volt-ohm meter, you should do a simple self check of the alternator as well (search for Youtube vids on the how to).
gatekeeper21
05-27-2009 08:00 PM
