Looking for a tool for my Volvo
Old 03-15-2017, 12:33 PM
strelnik's Avatar
Default Looking for a tool for my Volvo
I discovered in reading that there is a special tool for compressing the hydraulic piston which provides tension to the tensioner roller and keeps the timing gear tight.
The reading said the tool was expensive and rarely used.
Does anyone know about this tool ? Or have a source for it?
Any info on cost? Part number?
Am curious as to what it is.
Thanks!
Old 03-15-2017, 12:43 PM
ES6T's Avatar
Use a vice, slowly. Or replace the hydraulic piston and it comes compressed.
Old 03-15-2017, 04:13 PM
firebirdparts's Avatar
Yeah. A good vise is expensive, but of course you use it all the time. My problem is finding a suitable grenade pin to stick in the hole. You need something strong, and I typically use an allen wrench.
Old 03-16-2017, 01:59 PM
boxpin's Avatar
I have used a drill bit to hold the pin.
Old 03-23-2017, 12:07 PM
strelnik's Avatar
The spring steel used in larger safety pins may be an option, plus it can be closed, ensuring that the pin does not accidentally cause the plunger to move forward.
I have found one of these and am studying it. I may be making a much cheaper version for anyone who wants one.
Old 03-23-2017, 02:03 PM
Do you use it on the car? That is the only reason I could imagine needing a tool.
Old 03-31-2017, 09:03 PM
mountain_tamer82
11-01-2012 12:13 PM
autonumen
12-25-2011 08:11 PM
supmotelec
10-11-2011 04:55 AM
Michael7272
01-10-2009 01:47 PM
Carbuff
04-04-2005 01:38 AM
Quick Reply: Looking for a tool for my Volvo
