Auto transmission oil line stuck in radiator
Old Jun 16, 2021 | 11:15 AM
Mr.J's Avatar
Default Auto transmission oil line stuck in radiator
I'm replacing my radiator and I've gotten everything disconnected except the upper oil line for the transmission, I got the bottom one off with no issues but no matter how hard I try I can't get the upper one out, any suggestions on how to get it out?
Here's what im dealing with.
Old Jun 16, 2021 | 11:49 AM
That looks just a little rusty! Can you get the other end off where it goes into the transmission? and replace the line also? 9180542 or 9142789 depending on the year.
Old Jun 16, 2021 | 01:21 PM
tonyfr's Avatar
You will need to replace that line. I would just cut it off since you are replacing the radiator.
Old Jun 21, 2021 | 11:08 AM
firebirdparts's Avatar
That is horrific. Maybe the yellow stuff is glue. I agree, cut it off.
Old Jun 21, 2021 | 03:15 PM
Mr.J's Avatar
ahh thank you this helped loads i couldn't find the part
Old Jun 21, 2021 | 03:16 PM
Mr.J's Avatar
Yeah it really is, the part is on its way, I've tried everything but its so bad it started to bend the tools I was using to try to pry it apart
jwzhp3
Jan 6, 2012 08:48 PM
bobcat123
Mar 13, 2010 08:13 PM
bobcat123
Mar 13, 2010 05:18 PM
VJZ
Jan 17, 2009 07:53 AM
lister99
May 23, 2008 06:17 PM
