Oil in coolant reservior
Old May 9, 2008 | 12:33 PM
lister99's Avatar
Default Oil in coolant reservior
If this keeps up I'll be 5 stars before ya know it. So today I left my car runningin the driveway while I ran in the house for 10 minutes. WhenI returned I noticeda brown puddleunder the car near the front passenger wheel. I open the hood and see that the brown fluid is comingfrom the coolant reservior cap. Smellsand feels like oil mixed in the antifreeze. Check the oil and it's down a quart, but no evidence of anti freeze in there yet.I'm thinking head gasket. Any and all input appreciated. Thanks Bob 96 850 turbo 150k
Old May 9, 2008 | 02:33 PM
Ozark Lee's Avatar
Default RE: Oil in coolant reservior
My bet is that the oil cooler line inside the radiator broke.
...Lee
Old May 9, 2008 | 05:58 PM
lister99's Avatar
Well there's something I didn't know, but makes perfect sense. Would I be able to connect the input line to the output line, to bypass the oil cooler. Then flush the radiator, add new anti freeze and see if the problem goes away. If so I would think that anti freeze would leak out of the oil input or output on the radiator once the car warmed up. Or is there an easier way to pressure test the cooler in the radiator.
Old May 9, 2008 | 06:37 PM
Bypassing should be fine for testing.
Try that and see what happens.
Old May 10, 2008 | 12:37 AM
Psaboic's Avatar
I would think if it was a leaky head gasket, the motor would be running rough. One test I heard of that is supposed to work is to start the motor with the cap to the coolant reservoir off. If the head gasket is blown I'm told you will get bubbles from the coolant tank.
Old May 10, 2008 | 12:44 AM
Volgrrr's Avatar
ORIGINAL: Ozark Lee
...Lee
This is what I would be looking at also.
Old May 10, 2008 | 04:38 AM
lister99's Avatar
I'm leaning toward the oil cooler line in the radiator. Because the oil was forced into the cooling system, that tells me that it was under greater pressure than the coolant. If it were a head gasket, it's usually the other way around, coolant in the oil. Unless this car has a channel through the block from the oil pump that brings the oil to the top of the head, that passes near a coolant channel around one of the cylinders. Typically a blown head gasket burns through near the cylinder (it's hotest point) and then the anti freeze runs into the cylinder (being under pressure), causing hard starting and poor running, sometimes with visable water out the exhaust. Where as the oil channels aren'tunder pressure since they allow the oil to drain down from the head back to the oil pan.Whichis why I don't think it's a head gasket in this instance. I would think it rare for a head gasket to fail between a coolant channel and oil channel.
Old May 10, 2008 | 09:37 AM
Psaboic's Avatar
Agreed!
Old May 13, 2008 | 07:19 AM
JPN's Avatar
JPN
I don't think you needed to ask, you know a hell of a lot more than I do!
JPN
Old May 23, 2008 | 05:31 PM
lister99's Avatar
Thank you all for the time you spend here to share your expertise. Here's what happened next. I concured with Lee that it was the oil cooler line in the radiator that was the culprit. So I ordered a new radiator and all hoses, be sure to order the clamp kits for the oil and tranny lines that go into the radiator, the old ones are not reusable. I figured while I had the radiator out it would be a good timeto do the PCV repair so I did that too. If you do the PCV repair it's worth at least taking off the fan and cowling from the radiator, the added room is worth the effort, it makes accessing the bolts under the intake manifold much easier to work on. Now it's all back together and running fine again. Thank you all again.
Old May 23, 2008 | 06:17 PM
JPN's Avatar
JPN
Yay!!! And thanks for the helpful guidance.
JPN
carson850
Jan 7, 2014 02:08 PM
ridgerat
Jul 10, 2013 04:55 AM
no1pony
Sep 3, 2011 06:45 AM
robnov
Apr 14, 2009 04:57 PM
timk
Nov 16, 2007 08:33 PM
