Can anyone help with an IMMOBILIZER problem? 09 C70 starts, runs then shuts off.
Old 12-10-2016, 02:12 AM
Count Chocula's Avatar
Default Can anyone help with an IMMOBILIZER problem? 09 C70 starts, runs then shuts off.
**UPDATE 12/28/2016 SOLVED ISSUE BY HITTING UNLOCK THEN LOCK FIVE TIME FROM KEYFOB AFTER BATTERY WAS CHARGED**
It has sat for a few weeks not driven...battery WAS dead.
Needed a jump start.
Car starts, runs for 5-10 seconds then shuts off.
Immobilizer error on main screen.
At that point it wont even click to start again.
Key remains stuck in ignition so you cant remove it when this happens!!
Key comes out no problem when immobilizer error is not on.
Also lock buttons dont work when immobilizer is on.
Is there a way to reset this or diagnose without going to the dealer?
09 C70.
Bone stock. No modifications.
Roughly 70k miles.
Thanks!
The Count
Old 12-11-2016, 11:32 AM
MSGTUSMC's Avatar
Try removing & re-sitting brain module then disconnect battery 4 2 min then reconnect.
Old 12-12-2016, 01:26 AM
Default Thanks!
I'll try that. I can't seem to find the brain module location to unplug.
I read on a few other posts to try to unlock/lock from keyfob 5 times and checking the antenna ring on the keyfob or the ignition switch but all were for different Volvo models/years.
The Count
Old 12-28-2016, 04:20 PM
Just to help others that may stumble across this.
I'm guessing it was the voltage drop (from not being driven and battery charge dropping) that messed with the alarm.
Anyhow, after we finally got a charger on the battery,
LOCKING AND UNLOCKING FIVE TIMES EACH FROM THE KEYFOB WORKED!!
What a stupid and simple fix for days wasted researching and almost sending the car to the shop on a tow truck.
Next project is to figure out some type of hard-wired solar trickle charger.
Happy New Year everyone.
The Count
Old 01-14-2017, 01:04 AM
urfantasia's Avatar
Check your battery. My '11 had the same issue before and I brought my battery to autozone and they checked out to be bad battery.
Joe Redd
07-25-2020 04:37 PM
ChilinMichael
01-06-2016 10:53 AM
NoM54Me
11-09-2012 06:48 AM
hickdead
08-09-2009 02:12 PM
Wanttobecool
03-11-2009 07:21 PM
Quick Reply: Can anyone help with an IMMOBILIZER problem? 09 C70 starts, runs then shuts off.
