2000 S40 Low Beams
Old 01-14-2013, 03:17 PM
jpjmustang's Avatar
Default 2000 S40 Low Beams
I have a 2000 S40 - the low beams wont work, but the high beams work. I have checked the fuses (both of them) under the hood (10amp).
Any thoughts?
Old 01-16-2013, 07:10 PM
Hudini's Avatar
Bulbs burnt out? Not trying to be funny. Stranger things have happened.
Old 01-19-2013, 09:54 AM
jpjmustang's Avatar
Angry low beams
the whole story is that the passenger side went out first - put in a new H7 bulb - would not work. I ended up wiring the passenger bulb to the drivers side bulb so they would both work.
Now they are both out. fuses still good. Im going to start trying with a multimeter to hunt dont the circuit issue
JPJMustang
Old 01-19-2013, 03:10 PM
Metal Mickey's Avatar
possible bulb connectors, mine burnt out at black earth wire,replaced connectors trouble gone bulb ok
Old 01-20-2013, 08:13 AM
jpjmustang's Avatar
Default Sockets
I cut the sockets off ( the plastic was starting to crack and was very weak) and wired the bulbs direct.
JPJMustang
Old 02-02-2013, 02:04 PM
Johnny Hamm's Avatar
JP
Do you mean that you ran a jumper wire from the working light to the non-operable one? If so....is it still working?
Old 02-05-2013, 03:08 PM
matheunin's Avatar
I just had this exact problem with my 2000 S40. Right headlight out a couple years ago, and the other night both dead. I had already wired the right to the left and changed bulbs. It ended up being the CEM - Central Electronic Module. It's located under the dash and fairly easy to change yourself. Not so cheap, got a used one for $250.
Old 02-05-2013, 05:24 PM
Hudini's Avatar
Good to hear a solution. Thanks for posting the info.
Old 02-05-2013, 07:52 PM
The CEM has one relay for each low beam headlight...12 VDC, 15 Amp, 240 Watts SPDT, (single pole, double throw) connected to the CEM circuit board. A few owners have reported de-soldering the bad relays, and soldering in the 5 pin replacement that costs @ $1.50 on the internet. Also, some reported success and some reported problems with used CEM's purchased on eBay. MAke sure that you look at your CEM number to procure a matching one. Apparently this is a common problem accross all recent Volvos when the bulbs/fuses are good, but there is still a headlight fail. I am working on identifying the relay.
Old 07-22-2014, 03:57 PM
KLR142's Avatar
Any luck?
EDIT: Found more info: http://www.volvoforums.org.uk/showth...ight=headlight
Old 07-23-2014, 10:42 AM
The Internet company with the required relay is called Digikey.
The part number is JSM1-12V-5
Old 07-24-2014, 02:00 PM
Btw, the CEM is easy to remove, but splitting the case was maddening until I discovered a Philips screw hiding under a Volvo decal. I recommend you purchase a spring-loaded solder sucker (@ five USD) to insure a successful swap out of the relay. I am an Electrician but was still apprehensive about trying this myself, but knowing others had done it encouraged me. So glad I did.
98isb360
10-13-2021 08:47 AM
bkhan145
03-16-2019 02:22 PM
kwhitton
02-03-2018 09:45 AM
whatda?
08-09-2008 07:35 AM
jasonl
08-01-2008 08:25 AM
Quick Reply: 2000 S40 Low Beams
