Does engine oil stay in camshaft after engine off?
Hello guys,
I drive only a time a month, I'm afraid it damages my volvo.
I mean, whether there's anything more than sitting the car over night.
Engine oil stays in the top of the engine, say, camshaft right?
After engine off, does it fall down by gravity?
So I start it again it damages the cam somehow.
Is it true?
Is it true?
A small amount stays between the cam cover and the head but most of it falls down to the sump. After performing major work on an engine I always prime the engine before starting becuase it is bone dry but that requires a power probe. You can just turn the key and crank it over but stop it from actually starting. Do that a couple of times and that should do the trick.
damage
Hello guys,
Is it true?
Is it true?
Even though most of the oil has drained to the oil pan as soon as you start tuning the engine over oil is pumped back up to it. Maybe a second if that of running without oil, not worth trying to avoid.
Do you remember the infomercials for Z40 or ZMax or something like that, claimed to leave a molecule thick film on the metal no matter how long it sat? They would line up 3 or 4 engines on stands and run them, then pull the drain pan and keep running them. FInally they would pull the coolant lines and show that the Z? treated engines would keep running no matter what, whereas the untreated engine would lock up in a few minues of pulling the drain pan. Total crap. If it did have any significat effect on engine longevity every engine oil in the world would have it in it.
S40 MY07 starts right away as soon as I crank, with 2000 RPM so I'm just unfortunate..
Agreed.
Oh, I'm gonna go watch for the Informecials. Thank you for it also
jordank
01-16-2016 05:58 PM
sdat1333
06-14-2007 07:27 PM
