A question about safety
I want to have some work done on my 2002 Volvo s40. It requires
that someone get under the car to remove and replace the drive axles.
I have what you might call backyard mechanics. They know what they are doing. However, up to now, I will not allow anyone to get under my car that is just being held up by a carjack. That seems unsafe. Getting under a car that is being held by those small jacks in the trunk of a car does not seem wise.
Is there a way to make this safer? is there a was to rent repair bay time in
a repair bay that has a hydraulic lift?
Any help appreciated. Thanks in advance.
Respectfully,
Newport_j
Respectfully,
Newport_j
+1 here. You have several choices - ramps are enough to do an oil/filter change. Anything more and you'd want redundancy, ie a jack (ie bottle or hydraulic) PLUS jack stands. Pay attention to jacking points - don't use control arms or flat body panels - seams by the rocker panels are where the jack points are. When using stands make sure you pay attention to the footing - no soft dirt or directly onto hot asphalt. Finally always chock the wheels (on both sides) and use park and e-brake if possible.
Meloyler
01-03-2011 11:04 AM
