Recovering from broken timing belt: Where to buy valves
Old 05-15-2015, 08:31 AM
jgandee's Avatar
Default Recovering from broken timing belt: Where to buy valves
The timing belt was messed up by the serpentine belt. The small roping from the serpentine belt was pulled up into the timing belt. (first i have ever seen this). the roping broke the tensioner, and it was just like the belt broke.
I need to replace intake and exhaust valves. Do you get these from a dealer, or do you have other recommendations.
Thanks.
See bent valve pic.
Attached Thumbnails Recovering from broken timing belt: Where to buy valves-valves-.jpg
Old 05-15-2015, 03:05 PM
If you are not compelled to buy Volvo OEM ($50 a pop at tascaparts.com is the best dealer price you'd find), try EEUROPARTS.COM (Osvat or Intervalve after market can be had for about $15 each) . FCPEURO.COM also sells the parts but you may need to email or call if you don't see the non-Volvo parts on their web page.
Old 05-18-2015, 01:17 AM
Hudini's Avatar
I bought mine online after searching around for best price and availability.
Old 05-18-2015, 06:50 PM
jgandee's Avatar
Thanks. I will begin searching.
Old 05-19-2015, 01:27 AM
Hudini's Avatar
I had to buy 8 exhaust valves. I ended up buying from FCP Euro and went with the Iconel version because of the turbo. The top of the line sodium filled valves were just too much.
It was a few years ago so things have probably changed.
MarkRR
03-15-2013 08:09 PM
rbroy
03-24-2008 09:51 PM
girlie
12-26-2007 09:52 PM
itsagirl
01-29-2006 06:36 PM
blase
05-02-2005 01:20 AM
Quick Reply: Recovering from broken timing belt: Where to buy valves
