S40 transmission
Old 08-14-2016, 09:31 AM
Fer71457's Avatar
Default S40 transmission
Hello, as you can notice I don't have enough knowledge about cars and my transmission is going a little nasty (sometimes it lose power while I'm in the traffic and doesn't go up to 30 kmph until I turn if off and on, so I was wondering, may I do a transmission swap? I mean, A s40 II automatic transmission could be changed by a s60 automatic or another?
I know this sound too silly but I really want to know.
Thank you for your time.
Old 08-19-2016, 02:35 PM
Hudini's Avatar
I've never heard of anyone swapping trans to another Volvo model. Probably has to do with them being electronically controlled.
Try a drain and refill several times. Basically, drain out the old nasty fluid and replace with fresh fluid. Do this 4 times and you will have replaced 95% of the old fluid.
A flush and fill from a trans shop may work or it may kill the trans by loosening all the metal shavings that settle into the corners. People posting on here have had both outcomes. (shrug)
mason3325
12-22-2021 12:51 PM
jeffrisley
06-14-2015 01:48 PM
wilnis
06-27-2005 09:37 PM
Quick Reply: S40 transmission
