S40 won't start after sitting 7 months.
Old 02-20-2017, 06:00 PM
not-tall-or-smart's Avatar
Unhappy S40 won't start after sitting 7 months.
The car cranks and the engine turns but won't start, hardly even sputters. I checked that one of the spark plugs fires with a jumper cable and i did see spark. The Fuel pressure sensor was replaced and i was able to get a reading of 50-55 psi when a fuel pressure gauge was attached to the fuel rail.
I probably should have drained the gas but i didn't. It shows about half a tank
I noticed some rat poop under the hood.
Any thoughts on what you guys would try next? Thanks for your time.
Old 02-21-2017, 12:57 PM
did you try spraying some starter fluid into the intake? YOu may also try dropping a little oil in each spark plug hole in case you have dry rings. Maybe do a quick compression check to start.... What year is the s40?
Old 02-21-2017, 03:18 PM
It's a 2005 2.4i w/manual transmission. I did try spraying starter fluid but before the air filter. Seems like it did stutter a bit after spraying the starter fluid. I was getting a P0190 code, which is why i replaced the the Fuel Pressure sensor. Could 7 month old gas be an issue?
Old 02-21-2017, 03:35 PM
firebirdparts's Avatar
I doubt it very much. I have several cars that don't burn a tank of gas in a whole year; it's not usual to have trouble at all. The rat-chewed-wires hypothesis is would be more worrisome to me.
Old 02-23-2017, 03:18 PM
I do get compression. Im getting plenty of pressure to the fuel rail. Could it be clogged fuel injectors not opening?
Old 02-26-2017, 09:29 AM
Hudini's Avatar
It is possible that the injectors are clogged. I had clogged injectors from a junkyard engine that sat for several years. Of course the fuel smelled like turpentine once I got the fuel rail off.
You can hook up a noid light to make sure the injectors are receiving pulses.
Old 02-26-2017, 01:47 PM
I (removed and) energized each injector while forcing pressurized carb cleaner through them and they didn't seem very dirty. I assembled the fuel rail and saw them work removed from the intake as they should. I reassembled and still no go. I drained the fuel tank using the fuel pump (i removed the starter fuse and held the key in the 3 position) porting out to a paint bucket and added fresh 2 gallons of fresh gas. The old gas didn't seem too bad.
Old 02-27-2017, 05:35 AM
Hudini's Avatar
Did you check the fuses? I haven't checked the wiring diagrams to confirm but on other cars the injectors are normally powered and the ECM provides the ground to make them fire. No power = no fire.
Everything else being fine then I think a wiring issue as in the mice chewed up the wires. I've seen it on cars that are stored for long periods.
Old 03-07-2017, 08:06 PM
It ended up the timing belt slipped and was off by 8 teeth. Thanks for the help you guys.
Tiffany Ellis
1998-2000 model year V70
11-19-2014 10:39 AM
inkydink
12-31-2013 02:09 PM
jsmilde
10-20-2013 05:39 AM
solitarypasserby
12-11-2009 11:24 AM
copycat923
01-27-2006 01:55 AM
Quick Reply: S40 won't start after sitting 7 months.
