Thermostat Housing Assembly Torque Spec
Old 10-19-2014, 05:31 PM
Jeep7798's Avatar
Default Thermostat Housing Assembly Torque Spec
What are the torque specs for the thermostat housing assembly on a 2004 S40 with the 2.4i engine. Thank you
Old 10-20-2014, 06:36 AM
Hudini's Avatar
This thing? It's showing 10nm which converts to 88.5 inch/pounds (NOT foot/pounds )
Old 10-20-2014, 07:08 PM
Jeep7798's Avatar
That is the correct image but I think the 10nm are for the bolts that hold the thermostat housing in place. I need the nm for the three bolts that hold the entire assembly to the engine block. Last night I used the torque wrench to remove the bolts and I am estimating it took 10 to 15nm. Thank you for the help
Old 10-20-2014, 08:24 PM
pierremcalpine's Avatar
Not sure about those three but when in doubt here are the general torque values from VIDA which they suggest should be used when nothing is specifically stated in the install instructions:
M5: 5nm
M6: 10nm
M7: 17nm
M8:24nm
M10: 50nm
M12: 80nm
M14: 130nm
kendogg
12-27-2017 09:56 PM
jigen3
03-02-2011 02:45 AM
towjoe
09-02-2010 09:44 PM
texan_176
10-04-2009 10:05 PM
cb1313
05-23-2009 11:49 AM
Quick Reply: Thermostat Housing Assembly Torque Spec
