Need help on T-belt and need a torque spec
Old Oct 4, 2009 | 06:15 PM
texan_176's Avatar
Default Need help on T-belt and need a torque spec
I am in the middle of a prep on a used engine to swap in. The car is a 99 base S70 with auto trans.
Anyway...first question is..what is the torque spec for the rod cap bolts on the crankshaft. I pulled one cap to see what the journal looked like underneath it.
Then, according to VIDAS this car is supposed to have a hydrualic tensioner but I could not find one on the donor car which was also a base S70...99 model year.
Below is a pic of what I see on my engine:
Next issue is I am having troble finding the match marks on the cam gears and crank gear. There is a tiny line on the cams but they never line up. I also see a small "M" in the cam gears but they also never line up.
All I see on the crank is this line on the part between the gear and serpentine belt pulley.
Please help.
Old Oct 4, 2009 | 10:05 PM
Do you have the upper cover on when trying to line the marks up?
Vadis did not give the torque spec that you need?
kendogg
Dec 27, 2017 09:56 PM
VolvoXC90Car
Feb 2, 2013 11:05 PM
Bruce Ho
Sep 25, 2012 07:17 PM
towjoe
Sep 2, 2010 09:44 PM
cb1313
May 23, 2009 11:49 AM
