how long should control arm bushing last
I replaced both front lower control arms spring this year with Meyle from FCP. Now, less than 10000 miles and maybe 6 months later, the front bushing is already torn again. Is it me or is this "normal?" I know they are prone to tearing, but this is ridiculous. I can do the replacement fairly simply, but the cost and time is unacceptable. I would almost have to replace the control arm every 2 oil changes depending on how pristine I want to keep it. Letting it go is not an option either as the alignment will then be off and tire wear will then become an issue.
