control arm bushing
Old May 16, 2005 | 09:45 AM
cathym's Avatar
Default control arm bushing
Does anyone know if just the control arm bushing can be replaced or does the whole control arm need to be replaced? The bushing on the right front is worn. Thanks!! Oh...it's a '96 850.
Old May 16, 2005 | 10:49 AM
Default RE: control arm bushing
As far as I know they can be replaced.
I would have the balljoint checked as well because they are not replacable.
You will have to buy a new control arm if the balljoint is bad.
They can check it when they take the arm of to do the bushing.
Sometimes you can't tell the balljiont is bad till the arm is off.
Old May 17, 2005 | 07:28 PM
knight rider's Avatar
I don't mean to disagree with tech, but you can replace the lower ball joint without replacing the control arm. There are 3 nuts on the underside of the control arm that remove the ball joint. However, the whole assembly isn't but about $50 or $60 more than the ball joint itself I believe, but it is a lot more work to replace the control arm.
Old May 17, 2005 | 08:11 PM
Yes I agree some what!!
She has a 1996 the ball joints on there car are not replaceable.
Split year on the 1995 they changed the setup with the control arms.
You can't replace the ball joints on the newer cars.
Osiris1975
Nov 21, 2011 07:11 PM
Way2Fast245
Feb 14, 2009 08:04 PM
phoffman
Sep 2, 2007 03:07 PM
dpm2340
Nov 26, 2006 01:17 PM
dpm2340
Nov 26, 2006 12:04 PM
