Oil Leak 2008 S60
Oil Leak 2008 S60
I'm having steady oil leakage on my S60. Coming from front right of vehicle, opposite turbo side. Took it to a mechanic and they diagnosed it as an oil hose leading from engine to turbo. Replaced it and it is still leaking from the engine. Hose showed no cracks or seal problems, so that wasn't it. Mechanic is taking the axle off to see if it is an engine block crack. If it is...welding aluminum is tough, I'm told, so it might need a new engine. Car has 101,000 miles and has had no other problems before this. Not sure I want to drop that much coin on a car that is getting older. Could there be other culprits besides the engine block being cracked? I have been looking at some forums and see that PCV lines can get clogged, leading to an increase in pressure. Others mention the oil trap being plugged, and others mention a link between the cooling system and the oil line. The leak appears to be unrelated to the turbo, as that is dry, and is coming from the engine, but high enough that the mechanic can't see it without taking the axle off. Anybody know of what might make this problem occur besides a cracked engine block? Thanks for any help.
Try a different mechanic. Yours clearly doesn't know what he is doing. I would very highly doubt the block is cracked.
As damien said, the PCV can get clogged and cause various things. Oil can get drawn into the fresh air hose at the turbo, making it look like the turbo is leaking. A clogged PCV can also cause cam seals to leak. A leaking front cam seal can run along the back of the head and down the back of the block.
