2008 S60 Oil Change questions
Old May 3, 2009 | 08:45 AM
mekump's Avatar
Question 2008 S60 Oil Change questions
Sorry if this has been covered already, I couldn't find it ...... I am getting ready to change the oil and filter on my 2008 S60, first time for me on a Volvo. Do I need any special tools to remove the oil filter housing? What are the torque specs for the oil filter housing? Where does the oil filter reside, above or below the engine? I believe the torque spec for the oil drain plug is 28 foot pounds.
Thank you, Mike
Old May 5, 2009 | 07:18 AM
mekump's Avatar
i found the answers i was looking for at ipd. i ordered the T261K from ipd which includes 3 filters, 3 crush washers and the tool for taking the filter off. the torque spec for the filter housing is 25Nm. looks like the filter is assessable from under the car.
Old May 5, 2009 | 10:22 AM
jks2's Avatar
Glad you found what you needed. Make sure you keep up with the recommended service intervals. If you do your Volvo will last forever, almost.
volvoC70GA
Oct 12, 2013 06:06 PM
Phil 850
Jul 25, 2012 10:01 PM
shayne1106
Apr 18, 2012 06:08 AM
varioram
May 2, 2010 12:06 AM
lanwarrior
Dec 27, 2009 05:17 PM
