Retrofitting Xenon headlights
Has anyone ever installed factory xenon headlight assemblies in a car that came with halogen. I have a 2005 S60 that I have done this to and the lights will flash on for a second and then stay off. I believe the CEM needs to be reprogrammed to recognize the xenon lights. No one seems to know if this is possible, including several dealers. Thanks, Greg
If anyone is interested, I believe I have come up with a reasonable solution. The xenon lights, when first started, draw too much current thus shutting off the power from the CEM as it thinks there is a short. I am redirecting the low beam power wire to the DRLs, which should avoid a bulb out warning, and also using that signal to activate a standard relay to power the HIDs. What I still hope to find out is whether the CEM is different between HID and halogen cars, or is it only a programming difference. Thanks again, I'll post again when done, as I am waiting for a seat belt tensioner to get rid of an airbag light to see if I have any bulb failure warnings. Greg
Swer
01-09-2015 09:50 AM
