Sponsored by:
Sponsored by: DashLynx
S60R BLOWN FUSE TO FUEL PUMP AFTER STARTING
Old 12-27-2008, 03:18 PM
epbuku's Avatar
Default S60R BLOWN FUSE TO FUEL PUMP AFTER STARTING
Hello i have 2004 S60R After starting car it ran approx 3 seconds then shuts down, blowing the fuse to the fuel pump. This is the third time in the past month. Only happens when engine is cold (morning start up) Any help would be greatly appreciated.
Old 12-28-2008, 09:58 AM
Default RE: S60R BLOWN FUSE TO FUEL PUMP AFTER STARTING
I wonder if the fuel pump itself is bad.
Old 01-01-2009, 01:00 PM
mushroomxiii's Avatar
the s60Rs along with the xc90s had an issue with a wiring fault that causes the pump to fail early. there is a tech note that dealerships have that make them replace the pump and install a different harness to the pump. another thing is if you let your fuel level get too low as to where the light comes on it will also cause the pump to fail early. I have a 2005 s60 R and had to have this installed and now it runs great!
quick6black
06-11-2018 05:01 PM
shai_kino
08-20-2014 06:45 AM
bigvolvo
10-02-2010 07:05 PM
scrap88
04-07-2010 09:23 PM
mikerock88
02-18-2008 05:34 PM
Quick Reply: S60R BLOWN FUSE TO FUEL PUMP AFTER STARTING
