Sponsored by:
Sponsored by: DashLynx
Timing Belt and/or water pump?
Old 03-04-2009, 01:25 PM
heyitsomid's Avatar
Default Timing Belt and/or water pump?
I called the dealer today and they said that the water pumps don't need to be changed when the timing belt is changed. Only if it is faulty. I was wondering if this is correct or do I need to change it as well anyway.
Old 03-04-2009, 06:35 PM
01_fast_ride's Avatar
I just scheduled to have my timing belt replaced and asked the same thing. The Volvo specialist I talked to says exactly the same. He said, "Honda, Toyota, Nissan ... it's automatic, you do the water pump." He says Volvo makes their water pumps a lot beefier and that is why it is not necessarily needed. If there are signs of failure then they will advise you to replace it.
Old 03-04-2009, 06:48 PM
Somthngfrce's Avatar
What happens if you do the belt and 30 days down the road the water pump goes out! Yes, you might not needed now but what iif? Then you have to re-spend the same amount of labor, whereas right now you can just add the water pump for not much and call it insurance for later down the road... No one will know when the pump might go out, but IMO I would add it and know you wont have to do it for a looong while. But that's just my 2 cents.
Old 03-05-2009, 10:32 AM
heyitsomid's Avatar
Thanks for the advice. I would like some more feedback if any one else has any...
Old 03-05-2009, 07:54 PM
I usually don't replace unless it is leaking.
majorcode
11-04-2013 06:41 PM
lapwizrus
01-25-2010 08:40 AM
mortonight
01-23-2010 08:34 PM
volvofunny
09-12-2008 01:40 PM
zeeman
03-01-2008 06:16 PM
Quick Reply: Timing Belt and/or water pump?
