98 S70 non-turbo won't start
Old 04-17-2015, 09:07 AM
rtd59's Avatar
Post 98 S70 non-turbo won't start
My car won't start,it ran great before I was going to phx and after getting off the freeway it died at a stop light,it restarted a couple times then died right a way after each time.I had it diagnosed the guy told me it needed a Mass Air Flow Sensor and a Throttle Position sensor.I had him install both also a new air filter but it turns over but still won't start.I smell gas under the hood so I guess the fuel pump is working,I'm know nothing about cars any suggestions?I can't afford the shop prices or dealer prices..
Thank you.
1998 S-70
Old 04-17-2015, 03:12 PM
try pulling a plug to see if its wet. Its possible you've wetted down the cylinders with gas so there's no oil on the compression ring (google lawn mower syndrome for some postings). What gave the diagnosis of a bad MAF or TPS - did your guy pull OBD2 codes and if so, can you post the codes up? It remains to be seen what the original problem truly was - ie an ignition problem (coil/wires/plugs/rotor/cap etc) or a fuel delivery problem - MAF, TPS, fuel pressure regulator or a ECU component - temp sensor, another sensor. Often these cars cascade a set of codes so its rare that both the TPS and MAF would go bad - but it is possible for a fuel pressure problem to trigger a MAF code. First, see if you can find out what check engine codes are stored. Then try squirting a small amount of oil in the cylinders to help build compression (like you are doing a wet compression test). Crank and if no start, measure the fuel pressure at the rail. If that's good, then check for spark etc.
Old 04-17-2015, 07:55 PM
rtd59's Avatar
I am having another mechanic diagnose it monday.Hopefully he can figure it out.The first guy was a total idiot and drunk ,he would not show me what the codes were.I will be there Monday to see what's going on.I will post what happens.Wish me luck.
Thank you very much.
Old 04-27-2015, 06:52 PM
rtd59's Avatar
Put in new fuel relay,it ran fine for a few days,today it is the same as before turns over but will not start.Any suggestions?
Old 05-09-2015, 07:37 AM
Please don't post you car problems in "New Member".
Have you checked to see if the fuel pump cycles on when you turn the key and do you have spark ??
Old 05-09-2015, 08:35 AM
rtd59's Avatar
I hear the fuel pump it seems to be ok,i checked spark plugs for spark,found non.
Thanks for your advice..
Old 05-10-2015, 09:46 PM
Chances are good you have fuel then but it's time to check for spark coming from the coil in case you have a bad cap or rotor and you have spark but it's not getting to the plugs.
If no spark from the coil it's time to check things like the cam position sensor.
If you have room on a CC and you're located in the US you can see about getting a scan tool loaner from Oreilly, autozone ... Might be a code in the computer that would help you with diag.
Old 05-10-2015, 10:03 PM
rtd59's Avatar
i'll get the new coil by wed.if that doesn't help i'll check the cam sensor.I can't use a diagnostic tool as the first so called mechanic cleared all the codes..
Thank you very much for helping me...
Old 05-10-2015, 10:13 PM
Have you already checked spark from the coil to make sure you don't have any ??
You might want to test the cam sensor first. Testing is free compared to just replacing parts.
Even though he cleared the computer if you've been cranking it there might be something that's re-set into the computer for a failure code. Again it would be a freebee as you'd get a full refund on their "loaner" code reader tool.
Might want to add a location to you profile so it pops up. Someone might have or know of a source for some good used stuff in your area.
Old 05-10-2015, 11:02 PM
rtd59's Avatar
Yes Autozone said the coil was dead,so I ordered a new one.You think I sure check the camshaft sensor before I put the new coil in or does it matter?Checked still no codes?
Thank you!
Old 05-15-2015, 10:22 AM
rtd59's Avatar
Replaced coil today my car still cranks but will not start.
Ablorx
07-04-2014 08:33 PM
Lulumike
07-22-2011 03:02 AM
volvolove
03-21-2009 12:42 AM
biggmo
10-13-2008 09:15 AM
juliansea
06-16-2008 11:10 AM
Quick Reply: 98 S70 non-turbo won't start
