94 850 (non-turbo) won't start
Old Jun 9, 2008 | 06:45 PM
juliansea's Avatar
Default 94 850 (non-turbo) won't start
I changed my spark plug wires andsomehow got the wires out of order on the distributor cap. I When I turned the ignition, a small puff of smoke ascended from the distributor cap. Got a Haynes manual and wired accordingly. It still won't start. The engine just turns but won't start. How can I check to find out if I have the distributor cap wired properly? Is the Haynes manual correct? How can I determine if I have damaged the coil or power stage?
Old Jun 10, 2008 | 09:23 AM
JPN's Avatar
JPN
Default RE: 94 850 (non-turbo) won't start
No, Haynes seems incorrect. Try factory manual; see attached.
Next time when you do the wires, make sure to do them one at a time; I'm sure you've learned it by now.
JPN
[IMG]local://upfiles/6892/0B5822D3FF1C4D6B9DA1FB13B117EFBB.jpg[/IMG]
Old Jun 10, 2008 | 10:41 AM
Quick Brick's Avatar
Hey now Will,
http://volvospeed.com/Repair/sparkplugs.php
This may also help.
I have just noticed that there is a discrepency between Bay 13 and the page that JPN has provided. I'm not sure as to which is correct as I haven't seen mine since the engine transplant.
JPN, alittle help on this? You know more than I do here.
I'm unsure as to what youmean by "power stage"?[sm=insomnia.gif]
[sm=icon_cheers.gif]
Old Jun 10, 2008 | 06:37 PM
If they were the OEM bouigicord wires the plastic wire holders are numbered for the cylinders and so is the OEM cap.
Old Jun 10, 2008 | 07:29 PM
juliansea's Avatar
I got one of the black OEM cap covers off of a junkyard 93 850 today. Wired my dist according to cap numbers. Still won't start. Checked for spark. Got spark. This car was running until I changed plugs and mis-wired distributor. Thanks for your help thus far, JPN, Quick Brick, and Tech.
Old Jun 10, 2008 | 07:33 PM
Next check for fuel. If you have fuel then it should run.
Old Jun 10, 2008 | 07:41 PM
juliansea's Avatar
[&:]What is the proper way to check for fuel?
Old Jun 10, 2008 | 07:55 PM
Check and make sure you have fuel coming out of the schrader valve on the end of the fuel rail.
Old Jun 11, 2008 | 09:47 PM
hillbilly's Avatar
Didn't forget to put the new rotor button in? Or maybe the cap wasn't seated properly and broke the tang off the rotor button and that was the smoke you seen?
Old Jun 16, 2008 | 11:10 AM
juliansea's Avatar
Got it fixed! Removed spark plugs, placed a teaspoon of oil in each cylinder, replaced spark plugs, held gas pedal to the floor, turned the key for 20 seconds and PRESTO, BINGO-BANGO! The old girl started. She had been down for 10 days. Thanks for all of the help![sm=groupwave.gif]
ashort
Jun 11, 2015 09:40 AM
rtd59
May 15, 2015 10:22 AM
Ablorx
Jul 4, 2014 08:33 PM
Lulumike
Jul 22, 2011 03:02 AM
biggmo
Oct 13, 2008 09:15 AM
