Brakes 101
Old 03-23-2009, 03:38 PM
placer61's Avatar
Default Brakes 101
Sorry if this is a dumb question, but I have a brake issue I'm not sure about. When I am driving and press the brake pedal, I get some initial resistance, then it goes pretty close to the floor before the pedal gets firm and the brakes start working. All the pads are good, fluid is at right level, no leaks. From what I know about brake systems, I think I need a master cylinder. Does this sound about right? Or is there another part I should look at before going to the trouble? The car is a '98 S70, non-turbo, 40k miles. Probably original brake fluid.
If I need to replace my master cylinder, is it a tough job on this car?
Thanks again for everyone's help.
Old 03-23-2009, 04:33 PM
TIPSP's Avatar
Got Boost?
Sounds like you have some air trapped in the lines...Bleed the brakes and that should fix it.
Wait for others to comment
Old 03-24-2009, 09:02 AM
placer61's Avatar
Thanks for the tip, TIPSP. I don't know how air could have got into the system, though. It hasn't been opened up since it was working properly. I may just change the fluid, which it needs anyway. This will get any air out that may be causing this. I'm still thinking that I need a master cylinder.
Old 03-24-2009, 12:34 PM
TIPSP's Avatar
Got Boost?
Well...hope the bleeding works.
If not, then post back and tech or some one could probably assist.
Old 03-24-2009, 07:36 PM
I would try bleeding first!
Sometimes the air is trapped and does not get released for a long time.
boxpin
12-23-2011 10:43 PM
djgiovanni
02-04-2011 06:31 PM
rdharper
05-15-2007 12:31 PM
Autogeek
09-17-2005 12:58 PM
jhenry83
08-31-2004 05:57 PM
Quick Reply: Brakes 101
