Check Engine Light P0172 bank 1 system too rich?
Same for me
Please let me know where to locate the PVC Hose. This is happeng at 840 RPM Here's the stats: This is my first post so if this is too much info, just let me know: Replaced both 02 sensors last year and MAF 3 years ago-
Freeze Frame Information:
1. DTC for which Freeze Frame was Stored - P0172.
2. Fuel System 1 Status - Closed Loop - Fault With At Least One Oxygen Sensor.
3. Fuel System 2 Status - Not Supported.
4. Calculated LOAD Value - 2.75 %.
5. Engine Coolant Temp - 210.20 °F.
6. Short Term Fuel Trim - Bank 1 - 6.25 %.
7. Long Term Fuel Trim - Bank 1 - -5.47 %.
8. Engine RPM - 840.00 Rpm.
9. Vehicle Speed Sensor - 0.00 Mph.
Model year and mileage could be useful to guess what is going on.
BTW, I am no mechanic nor car expert. I am just a new Volvo owner who is struggling to keep my car on the road. What I notice unusual from my experience is that your LTFT is negative while you get rich condition code.
If it was from vacuum leak, I would expect a lot higher LTFT, as ECU would trying to compensate un-metered air.
So, what I would rather guess is something like this
https://volvoforums.com/forum/showth...ighlight=p0172
Well, I have to admit that this still does not make clear sense because your problem is under idling not under boosting.
In addition, if I have to use silicone sealer, I would use sensor-safe one.
grndslm
02-24-2014 12:01 PM
pnhons
04-16-2011 10:04 AM
