Fuel Rail Shrader Valve replacement?
Old 09-02-2015, 03:11 AM
Will Drake's Avatar
Default Fuel Rail Shrader Valve replacement?
Hi, guys. New to this site but have a weird issue. I have a 1998 S70 GLT that decided to just stop running. Replaced the cam and crank sensors since the connections were a little brittle, and of course still not running. "Tried" to test the fuel pressure off the shrader valve on the fuel rail and ended up breaking the test equipment. Now here's my problem. I'm pretty sure it's my fuel pump but in the process of trying to test it I destroyed the shrader valve on the rail. Before I go any further in this, does anybody know if the shrader valve is replaceable?
Old 09-09-2015, 08:17 PM
You will likely have better luck posting your car questions in your cars area instead of "New Member". That's just to introduce yourself and your car to the group.
I've moved it for you.
Old 09-12-2015, 01:53 PM
PMOURASSA's Avatar
Yes it is replaceable in any car,i replaced mine.S70
Old 09-12-2015, 02:40 PM
You might need to call Volvo on a part number. Tried a couple sources and I can't find it. It needs to be specifically for fuel, not for a tire or AC. A tire valve tool will work to take it out and put the new one in.
Here you go.
guest01
05-29-2014 09:20 AM
kkzdad
03-19-2012 12:48 AM
MHUSTON
12-13-2007 06:45 PM
S70driver
03-26-2007 05:50 PM
edahlgren
10-07-2005 09:53 PM
Quick Reply: Fuel Rail Shrader Valve replacement?
