fuel rail with schrader valve be swapped on my 88 740T
Old May 28, 2014 | 09:59 PM
guest01's Avatar
Default fuel rail with schrader valve be swapped on my 88 740T
fuel rail with schrader valve be swapped on my 88 740T????
would make life so much easier to diagnose fuel pressure issues.
Old May 29, 2014 | 01:20 AM
I don't know if the LH2.2 and 2.4 fuel rails are compatible.
Old May 29, 2014 | 09:03 AM
guest01's Avatar
Lame. Okay.
Old May 29, 2014 | 09:20 AM
swiftjustice44's Avatar
Not lame at all. The only difference is whether your 2.2 car uses a cold start injector which connects to the fuel rail. Later models simply used the computer to richen all 4 injectors rather than relying on a 5th cold start injector. If you do decide to go that route, be sure to get the injector clips as well as they are different on the later rails.
volvoaj
Mar 6, 2014 07:12 AM
GrantRobertson
Jan 29, 2014 06:21 PM
dirtysouth_boy
Aug 24, 2011 12:12 AM
edahlgren
Oct 7, 2005 09:53 PM
jorge8850
Jul 8, 2005 11:23 PM
