S70 Speedometer/odometer issue.
Old 07-11-2011, 09:04 PM
Angelnl's Avatar
Default S70 Speedometer/odometer issue.
My speedometer has stopped working for some time now (it would go on and off) but i just took this in stride. Recently I noticed my odometer stopped working too (not increasing in millage as I drove). When I restarted the car, both the odometer AND speedometer started functioning. In the middle of a drive, I realized the speedometer gave out, only to find that the odometer had given out as well.
Are these 2 related? (Since the speedometer doesn't read speed, the odometer doesn't record millage) or are they 2 seperate issues. I've seen the website to take out the ABS to get it fixed and solve the speedometer issue, and another website on fixing the odometer (taking it out and replacing broken gear). Am I going to have to do both of these things in order to fix both the issues?
Old 07-13-2011, 05:04 PM
Crush's Avatar
well the broken gear is for the manual odometer. i think you have a digital odometer. in that case i think either your abs module is shot (maybe). any lights on like abs or check engine or an arrow pointing up?
crush
Old 07-14-2011, 08:24 PM
ablesdd's Avatar
There is a quick fix for this problem, we recently had a discussion on this same topic a month or so ago. Here is the link to help you out. Volvo S70-V70 Abs Module repair | Car Instructions Good luck
Aimes87
09-11-2013 04:03 AM
Cefore
05-03-2009 03:49 PM
vanagon
04-12-2009 10:43 PM
jtvrba
12-13-2006 08:36 PM
lisrobbe
02-27-2006 09:50 PM
Quick Reply: S70 Speedometer/odometer issue.
