Volvo s70 weird noise under the Hood
Old 10-03-2016, 10:18 AM
PMOURASSA's Avatar
Default Volvo s70 weird noise under the Hood
My car is a 1998 n-Turbo,the car runs fine,no codes,but I am having this issue.
when idling or driving slow and not on the Gas pedal,there is noise coming under the hood a whistling type of noise,as soon as I press the gas Pedal the noise goes away,it is not coming from the serpentine belt,for certain it is closer to the driver side where the canister is or that module that,s connected to the throttle body,not sure what it is called.
Anyone have a clue?
Old 10-03-2016, 02:53 PM
does it change when you pull out the dip stick or remove the oil fill cap? Google "volvo s70 vent box" for some similar posts. Also could be vacuum or intake leaks...
Old 10-03-2016, 03:49 PM
PMOURASSA's Avatar
Thanks will give it a try when I get home.
Old 10-04-2016, 02:49 PM
PMOURASSA's Avatar
Default Humming Noise
Unfortunately,whether I remove the dipstick or Oil Cap,the Noise is still there,but there is Pressure for certain,only little Fume come out of the dipstick not a lot
dchludzinski
01-28-2010 05:20 PM
RuslikUA
05-01-2009 08:01 PM
lsmith
12-10-2007 04:57 PM
lsmith
12-08-2007 04:39 AM
hohoho43
11-02-2006 10:08 PM
Quick Reply: Volvo s70 weird noise under the Hood
