Water Temp. Sensor
Old 01-22-2010, 04:15 PM
s70_t5_1999's Avatar
Default Water Temp. Sensor
So I guess now that my brakes are fixed I'm looking at replacing the water temperature sensor. Before I do anything 1)Where is it? There is a big hose going from the radiator to the engine, and a small wire and what looks like a sensor below it, is that it?
and 2) Do i have to drain the coolant to get at this thing?
Old 01-22-2010, 10:36 PM
karutunian's Avatar
On a non turbo car...it's on the coolant overflow tank. Pull the tank up from it's holder and you'll see it on the bottom. I imagine you'll lose some fluid that's in the overflow tank, but not much.
Ken
Old 01-22-2010, 11:31 PM
akem21's Avatar
Are you looking for the coolant level sensor or the actual coolant temperature sensor?
For the non-turbo:
The level sensor is under the reservoir.
The temperature sensor is where you said it was. Under the large hose on the engine. That's also where the thermostat is located.
I imagine it's the same for the turbo motor.
Old 01-23-2010, 09:17 AM
karutunian's Avatar
akem...thanks for clarifying the difference. All the while I was thinking of the coolant level sensor.
Ken
Old 01-23-2010, 06:30 PM
chachouu's Avatar
Banned
Question
Ken
lol,He clearly stated water TEMPERATURE sensor.
you must have been too eager to help or had one too many,lol
Old 01-23-2010, 07:52 PM
akem21's Avatar
haha No problem. I've made that same mistake too many times.
Old 01-24-2010, 03:35 PM
yeah its the temperature sensor. and i'm replacing the thermostat as well. will i have to drain the coolant? or can i maybe just drain a little? i don't really want or need to flush it because i just did that a week ago
Old 01-24-2010, 06:49 PM
Paulie's Avatar
My remedy : two gallons of ice cream. Just wash out the buckets when you're done and you're good to go. Draining and refill is easy like sunday morning that way.
I suspect you only need to get enough out to get the upper radiator hose empty.
Quart of Ben and jerry's?
blackbrick
05-07-2011 01:46 PM
cisopen
09-20-2010 05:25 PM
nvs40
12-30-2006 12:14 AM
vcolper
11-01-2006 10:20 PM
jeff-abalone
07-03-2004 06:33 AM
Quick Reply: Water Temp. Sensor
