TIE RODS ,S70 1998 non-turbo
Old Jan 11, 2010 | 06:04 PM
chachouu's Avatar
Banned
Default TIE RODS ,S70 1998 non-turbo
Is it always a MUST that you replaced both Outer and inner.
someone suggested that if the outer is damaged,most likely THE INNER ARE bAD AS WELL.
I AM CHANGING MY OUTER.
Old Jan 11, 2010 | 06:31 PM
Carrots's Avatar
No... if the inners are tight, then only change the outer. The inners are better protected, and tend to last a lot longer.
Old Jan 11, 2010 | 06:34 PM
chachouu's Avatar
Banned
thanks.
Old Jan 13, 2010 | 02:27 PM
chachouu's Avatar
Banned
Btw,how hard is it to remove and install these myself.
I am not very handy,but all I see is one bolt and unscrew the other end,I know i need alignment right after.
Old Jan 13, 2010 | 07:13 PM
Paulie's Avatar
Paint your threads and the nut with a nice bright color so you can get the alignment close on reassembly. Hardest part will probably be coercing the joints loose. I like those tie rod/ ball joint separators that are like gear pullers. But there's nothing wrong with a pickle fork and a bfh.
I changed my inner at the same time. I wouldn't recommend it unless they're bad, it wasn't a whole lot of fun.
Old Jan 24, 2010 | 08:08 PM
cn90's Avatar
In my experience, OUTER Tierod lasts about 70-80K miles.
INNER Tierod lasts about 130-150K miles.
This is because the OUTER Tierod does the work when the car turns R and L everyday.
The INNER Tierod only works hard when the wheel goes up and down (such as going over potholes etc.). Also, being deeper inside, the INNER Tierod balljoint moves much less than the OUTER balljoint.
Clacquam
Nov 26, 2014 09:01 PM
Bigbluevolvo
Oct 12, 2011 08:59 AM
buckquark
Oct 29, 2007 10:47 PM
SDozier
Jun 27, 2006 12:40 AM
EBITDA
Nov 8, 2005 09:14 PM
