Where can I buy a new SAS Valve ?
Old 10-19-2008, 07:53 PM
msm15's Avatar
Default Where can I buy a new SAS Valve ?
Hi I had the P0410 error code I know its the secondary air system. I checked it out, first of all the rubber elbow by the SAS valve was destroyed I replaced with something but it is only temporary. I just replaced the pump with a used but working volvo OEM pump. When I removed my old pump there was no water in it at all but I ran a 12 volt source across the ends and it proved to be dead so I did the swap and put on a temporary rubber hose on the elbow in the mean time.
So far I have not heard the pump turn on any of the times I started the car. I know the new pump works I testd it myself.
I have not changed the SAS valve and should probably be using a better hose for the elbow - would these things still be causing the pump not to go on. I reset the codes after I did the swap but only drove around 25 miles or so - So I still have not got the error code back but I know it does take a while for it to come back.
Does any one know where I can buy a new SAS valve and the rubber elbow, I checked FCP Groton but couldnt find it listed anywhere ?
Also is there anything else I should be looking for ?
thanks
Old 10-20-2008, 12:01 AM
TIPSP's Avatar
Got Boost?
Default RE: Where can I buy a new SAS Valve ?
Try this site: http://www.fcpgroton.com/
Old 10-20-2008, 08:05 AM
http://www.fcpgroton.com/category-ex...61/by_year/48/
There is a link to everything in the air pump system. The vacuum line will be fine to leave it like that.If you really want to replace the elbow with an elbow here is a link to them as well.
Did you replace the relay?
The relay might be bad as well.
Old 10-20-2008, 08:41 AM
msm15's Avatar
I checked the pump today I pulled off the hose leading from the pump into the air filter and I could hear the pump working it was blowing air into the filter but it was not a very strong flow at all if anything it was a very soft flow is this the way it is supposed to be working ? also is it supposed to be flowing into the air filter or sucking air from the filter ?
thanks
Old 10-20-2008, 08:53 AM
I believe it pumps air into the air box.When the SAS valve opens it pumps the exhaust back into the motor to help heat the motor up.
Old 10-20-2008, 10:27 AM
msm15's Avatar
Ok thanks tech
rcvolvo
12-12-2012 09:15 AM
pirateonavtx@yahoo.com
12-26-2011 08:02 PM
Pharsyte
09-25-2011 03:55 PM
7 VII 7
02-24-2011 01:11 PM
nikez07
11-14-2010 07:08 AM
Quick Reply: Where can I buy a new SAS Valve ?
