2000 S-80 Persistent codes P1618 +P0751
Hi ROJO,
I haven't done anything yet, I am not sure if this is not an electrical problem, maybe TCM. There are times when after resetting codes the trans works fine shifting all four gears, but I am also getting ABS and STC and brake warnings. I believe its all electronic. Whenever I figure it out I'll let you know.
Mutley530
Mutley530
Mine will drive perfectly all day if left in 3, when shifting into "D" from 3 it does not attempt to shift into 4th at all but it does unlock the converter then after around 10 seconds with go into limp mode, I think with my car it may be a line pressure issue as I was told the solenoid was already changed.
