2002 S80 T6 Massive Oil Leak!
I have a 2002 S80 T6 with 80K miles on it. I've been changing the oil regularly for 6 months that I've had it.
I noticed there was a lot of oil coming from my vehicle on the ground where I park at work. I popped the hood and there was oil EVERYWHERE! Shallow puddles on the manifold, and all over the engine. There is oil dripped all over the rear and center of the alternator. There's also a lot of oil on the center return hose for the turbo. The oil is running down and blowing back all over the chassis. It's insane and I have no idea why the hell it happened. I checked to make sure the oil cap was on properly and it was. However, there was a lot of dark brown/black gunky oil residue where oil is put into the vehicle. Also the dipstick was not sealed down and was kind of poking out.
Aside from this I'm also running a little rough between 60-80mph.
Does anyone have any idea what might be causing this problem?
I bought the car used because it appeared to be in great shape and was at 70k miles..
Any help is greatly appreciated..
EDIT:: Could this have something to do with the crankcase oil trap or breather box? Not that I know what that is, but how much is that repair?
I wouldn't say its definately a "clogged" box but there's a very good chance that its leaking from the seals behind it. I was loosing 1qt/30miles or something when mine was leaking!!
Its easy enough to fix. P/Ns you need are
30713120 PCV Breather box "top" seal
8653339 PCV breather box "bottom" seal
9458535 Inlet Manifold Gasket
947282 Copper washer for the vacuum bolt on L/H side underneath manifold)
Other stuff thats a good idea:
9497454 PCV breather box (black box underneath manifold)
8636753 ETM to manifold gasket. You might as well clean the ETM while you are in there, especially if theres a lot of oil around there.
Was the car overfilled with oil at some stage? If its overfilled sometimes it will pass oil from the PCV dank down the line and into the inlet! Either way, clean out the oil in the pipes and the intercooler too. This oil could be from failing turbo seals, but at this stage I wouldnt panic, its more likely to be PCV related. Change out the spark plugs too, cheapie coppers will do for now while you figure out the peformance issues. Gap them to .028"
What do you think about this?
I'd like to get the PCV kit from IPD. Any thoughts?
http://www.ipdusa.com/version.asp?st...925&V_ID=14650
There were several small rubber seals/washers and a green small seal plastic that were left over. there's a banjo bolt on the Pcv nipple next to the dipstick and I don't think I sealed it right. drove off and have a squeaking noise coming from the s belt area. coolant was extremely low prior to that happening as I didn't tighten down a hose and lost all coolant .. now there is white steam and a hiss coming from somewhere in the engine and the squeaking noise. I'm so screwed.
Don't panic yet. The hiss is probably a vac leak from the 17MM nut under the inlet manifold (or coolant). The coolant leak is probably from where the PCV coolant pipe attaches to the back of the head. You need two copper washers one between the banjo thing and the cylinder head and another between the banjo thing and the head of the bolt. If you didnt get new ones the get em from the dealer. They are cheap enough.
Yeah need the one under the the manifold next to the dipstick. Thats the one I forgot to seal. Everything seems good though except for the squeaking noise from the s or timing belts.. could be gunked bearings from pulleys? A lot of oil and coolant has cakes my engine. No excessive pressure or leaks now though.
The P/N for the washers that go on the 17mm "vacuum" bolt is 947282. You need two, one between the banjo thing and manifold and another between the banjo thing and the bolt.
Not sure on the noise...is it time to do the timing belt?
Ok
Got a free cam shaft position sensor housing from the dealership and some of those copper washers for the banjo bolt.
Here's the deal.
Put the washers on and I still feel like there is hissing under the UIM, can't be sure because the damn TAPPET! sound is so loud haha.
The squeaking is gone must've been gunk...
Any ideas? When we put the elbow (nipple thingy that requires the banjo bolt next to the dipstick mounting...) on the car it was a really hard fit and the parts look a little too breakable.. Do you think the damn thing could've broke when I put it on? I really don't want to take the UIM off again because its a huge pain in the butt.
Also, replace tappets/lifters or sump seals?
Thanks guys
Here's the deal.
Thanks guys
WIN!
Here's the deal.
Sump seals. P/N for the kit is 30750783
1998S70GLT
04-23-2010 07:38 AM
