2003-2004 S80 engine reliability?
I am looking for an used S80 (2003/2004). As far as I know, they come with three different engines:
inline 6 (2003)
inline 6 turbo (2003/2004)
inline 5 turbo (2004)
Which engine would be the most reliable? I know other specs as hp but reliability is what concerns me the most.
Thanks.
inline 6 (2003)
Thanks.
RE: 2003-2004 S80 engine reliability?
I have a 2004 S80 inline 6 (non-turbo) 56000 miles. We've had the car since April 2004 (bought used), no problems so far. Just changed the plugs and air and cabin filters. Normal 3,000 mi oil & filter changes. We had the chance to get the 5 cyl turbo but opted for what we were told was a more trouble free 6 cyl non-turbo.
ORIGINAL: drabina
inline 6 (2003)
Thanks.
inline 6 (2003)
Thanks.
I've got a 2003 2.9 six and tranny was hesitating, sometime shifting hard into the next gear. Flushed it and she's shifting smooth as silk again. Gonna have the tranny filter replaced next oil change.
As far as engine itself, I've amazed how much torque it produces ~2000 RPM. I wouldn't want the exhaust wide open, even for a few more horsepower at higher revs. It's just so easy to drive the way it is now (stock), especially in traffic. I can sip a steaming hot cup of coffee during rush hour without spilling a drop.
I dunno, thinking maybe I should buy the trany filter and pan gasket and try to get one of the local transmission specialty shops to do it. Maybe print out the procedure I found here just in case: http://volvospeed.com/Repair/s80_transmission.html
Anywho, all other GM transmissions need maintenance, so don't understand how Volvo can say this one doesn't. A little TLC is all my S80 has need so far and it's running like a top.
I paid someone to do it for me ($150) but am pretty sure was normal ATF Dextron III. Just don't think I trust the same guy to drain and drop the pan. I wouldn't want it to get bent and not seal well afterwards. I suppose the guys in the trany shop, since they do that kind of thing all day, are probably a safer bet.
Well as far as I can remember, the stealership charges $140 for a flush including labour and ATF etc...
i figure may as well do it there at that price..
Is there any advantage to using synthetic ATF in the GM tranny?
they claim the filter isnt changeable but if its a filter it has to be changeable.. strange, varies between opinion i guess
I'm surprised your dealer even does it. I was told it's "maintenance free" and doesn't need to be flushed. No wonder so many are failing.
And I thought all that red ATF stuff was synthetic... my Honda Passport (Isuzu Rodeo rebranded) has a manual/stick that uses regular engine oil though. I put Mobile One in it just so I wouldn't have to change it again for a while. It's a pain to fill.
I did read on one of the other Volvo forums that there's a software patch ($115) for the transmission that prevents the "auto-neutral" on stop feature. Apparently that's why the car rolls back on hills and many suspect it's also the culprit in a lot of the premature failures.
faisduvtt
2001-2013 model year V70
03-18-2019 03:29 PM
