Go Back   Volvo Forums - Volvo Enthusiasts Forum > Volvo Vehicles > Volvo S80
Sign in using an external account
Register Forgot Password?
Search
Welcome to Volvo Forums!
Welcome to Volvo Forums,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Volvo Forums today!
LinkBack Thread Tools Search this Thread
Old 09-16-2008, 09:39 PM
Default Bulb Failure Dipped beam?????
does anyone know what this is? Both front headlights are out and do not work in any switch position!
Thanks,
Chuck
Old 09-16-2008, 09:43 PM
2002 Volvo S80
Default RE: Bulb Failure Dipped beam?????
Sounds to me like your bulbs need changing and the code is just telling you that fact....
I'm refering to the low beam bulbs, they are socket h7 and can be purchased pretty much anywhere
__________________
2002 Volvo S80 2.9
1997 Honda Accord EX 2.0 F20B2
http://i509.photobucket.com/albums/s...ility004-1.jpg
Old 09-16-2008, 10:42 PM
Same thing happened to me twice in one year on my 99 s80. When I took it to the dealer the first time it turned out to be a burned out resister so they changed it for $40. When it happened again after a few months I took it to the dealer again and it turned out to be a burned out shunt so they replaced it for $120 parts and labor. So if the bulbs are not bad I'll bet you its ethier a burned out Resister or a burned out Shunt. Take it to the dealer and have them check it out.
__________________
Ayaz Ahmed
Old 09-16-2008, 11:14 PM
2002 Volvo S80
Wouldnt it be cheaper and easier to test to see if its the bulbs first? you can always just try one of the bulbs from your high beam in the low beam and see if it works... that way you know its just that you ned replacement bulbs.. you can get those replacements pretty much anywhere if thats the problem..
__________________
2002 Volvo S80 2.9
Old 09-18-2008, 06:21 AM
I have read that other volvo cars with this problem may need something called a shunt? Is this the same for the S80?
Old 09-18-2008, 12:09 PM
Yea its called the shunt for the S80 also. As I said I got mine replaced at the dealership for $120 parts and labor not too long ago.
__________________
Ayaz Ahmed
Old 09-21-2008, 10:11 AM
The head lights started working again without doing anything to them? Does this sound like it could still be a shunt or a relay? The reason I ask is so I don't tear everything apart and find that it is something else. Does anyone know exactly where The shunt is located uuder the dash? I don't even know what I'm looking for once I'm under there. Thanks Again,
Chuck
Old 09-21-2008, 01:14 PM
I heard the shunt and relay are located under the driver side dashboard. However I have no idea what they look like since I have never been down there because I had the dealer worked on it.
And the Bulb Failure Dipped beam message started to come agian last night with my headlights not working. This is the 3rd episode in one year. I had the shunt replaced just3 weeks ago as I said above. And I also had the relay replaced not too long ago along with the headlights. So this is starting to get a bit annoying now.
__________________
Ayaz Ahmed
Old 09-21-2008, 05:19 PM
The shunt is under the dash on the drivers side see like for a general idea where it is.
http://www.xenonvalot.com/xenonfixvolvo.html
__________________
1987 Ford mustang LX Coupe 5.0
1995 Yellow T5-RM running
1996 850 turbo
1994 N/A 5-speed wagon Purple (daughters)
Tags
2002, 29, 99, beam, bulb, dipped, failure, h7, head, light, problem, s80, shunt, volvo, xc70
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
Secure Backup
