Car pulls hard to the right under hard power
Old 05-22-2006, 02:24 PM
jerryman's Avatar
Default Car pulls hard to the right under hard power
Yeah, it's me again. On the road at a cruise, I noticed the car pulls a bit to the right, so thought I would just take it in for alignment. But notice when I give it a lot of power, it pulls HARD, Very HARD to the right. Recently the car had the front end gone though because it was knocking, then the shafts/CV joints. Any idea what could be happening?
JC
Old 05-22-2006, 02:46 PM
Default RE: Car pulls hard to the right under hard power
Are you hearing any noises, or is it simply just pulling. The easiest solution would be to get the alignment done, and see if the problem persists. Or just take it in for a diagnostic.
Old 05-22-2006, 04:29 PM
jerryman's Avatar
no noises, went through that when I first got the car, they replaced all the bushings and rubber spacers by the struts.
Old 05-22-2006, 05:04 PM
I'm really at a loss then! I have no idea what the problem could be. I'm sorry man, but I would take it in to the shop and let them tell you what's wrong, for $50.
Old 05-22-2006, 11:37 PM
If it is AWD, then this wouldn't be it---if your car is FWD, i would guess either wheel balance, or just common torque steer. I have an S80 and it runs just fine. If I really punch it doin about 10 mph out of a turn, it pulls to the right. You just gotta get used to the control. The car has one drive wheel until the STC kicks in (the right wheel, I believe) so you will have drift when youre at lower speeds and high RPM's.
Old 05-23-2006, 01:19 AM
ORIGINAL: JCVolvoS80
+1
Rkotseos
Forum Issues
02-19-2015 11:31 PM
sgreenfield
08-17-2012 08:45 AM
chef
05-24-2011 11:34 PM
Pinto
07-20-2009 07:46 PM
gulf200
06-18-2009 04:15 PM
Quick Reply: Car pulls hard to the right under hard power
