intermittent low oil pressure light.
Old 03-16-2014, 12:01 PM
gargoyle's Avatar
Default intermittent low oil pressure light.
My 2001 S80 (2.9) oil pressure light started coming on at speed, not while idling. Turn the car off for 5 minutes and it may come back on after driving 4-5 minutes and it may not. The dealer fixed the oil pickup tube and it seemed OK. Now it's doing it again after 300 miles. They checked it again, and it took some time for them to get to a low pressure state (using a gage.) Now they think it's a bad rod bearing. I can't imagine it would do that intermttently. Maybe once the engine warmed up and every time, but not 300 miles later and occasionally. I'm wondering about clogged oil return lines or a malfunctioning oil pressure relief valve. Any ideas? Thanks
Old 05-04-2014, 08:38 AM
gargoyle's Avatar
My mechanic replaced the oil pump and the bypass valve. Thought maybe the valve was bad as I've read they can crack. He ran it then when he kicked it down at about 3500 it lost pressure.
Went to almost 0. Turned it off and it got back some pressure, but not to normal. Let it sit and it regains pressure again until you get to about 3500 again. Any ideas?
Old 05-04-2014, 10:31 AM
damien360's Avatar
How is your pcv system?
Old 05-04-2014, 01:41 PM
gargoyle's Avatar
No idea. Can that kill the oil pressure? Hadn't thought it could, but I'm not a mechanic.
Old 05-04-2014, 03:45 PM
damien360's Avatar
Trust me I didn't think it could either. We had a couple of cars come in that needed pcv cleanings so we did them, afterwards the cars came back with low oil pressure lights with symptoms exactly like yours. We replaced everything and performed numerous oil flushes to the cars and it kept happening. Eventually we decided to plug the pcv system even though everyone including Volvo said it would not do anything. With the pcv system plugged again the vehicle never lost oil pressure ever again.
Old 05-04-2014, 05:15 PM
oragex's Avatar
When the pcv clogs, it causes sludge inside the oil pan. from there, it can burst a rod bearing, or can clog the oil pick up tube. Did you had the oil pan removed for inspection? Removing the pan also gives access to clean pcv drain holes inside the pan.
Old 05-04-2014, 06:43 PM
damien360's Avatar
Trust me oragex. We inspected and replace everything that had to do with oil pressure. Plus im pretty sure sure the sludge issue had been fixed with the 10-15 oil flushes that were done to the engine.I understand your thinking but you also have to think of it this way, there was no oil pressure problems before the pcv cleaning with a clogged pcv. Then after the pcv cleaning that's when the oil pressure problems started to happen.
Old 05-17-2014, 10:34 AM
gargoyle's Avatar
Been on vacation. the PVC box or whatever it's call was filled with sludge. Waiting on a seal that got damaged during removal to try again. The pan was removed and the pick up tube cleaned originally. waiting for the seal to see if cleaning the box helps. the pressure was 90 psi till the engine hit 3500 rpm. Pressure fell like a rock. Turn it off and restart and got a little pressure back. WAit a while and it gets pressure back till you hit 3500 again and then you have zero. Thanks again
Old 05-18-2014, 10:34 AM
oragex's Avatar
You mean, the oil pressure drops to 0 above 3500 rpm? The o-rings seals inside the oil pan were replaced/inspected?
Old 05-18-2014, 08:55 PM
gargoyle's Avatar
yes, oil pan cleaned and the pickup tube cleaned and new orings installed.
Old 05-18-2014, 09:01 PM
gargoyle's Avatar
Looks like I had a private message, but I can't open it.
Old 05-18-2014, 11:06 PM
damien360's Avatar
Have you tried reposing the oil pump
Old 05-19-2014, 03:09 PM
gargoyle's Avatar
Replaced the oil pump.
Old 05-20-2014, 06:46 AM
oragex's Avatar
Just an idea, the oil pressure sensor might have an issue?
Old 05-20-2014, 09:50 AM
gargoyle's Avatar
My mechanic is using a guage. Thanks,
Old 05-20-2014, 09:51 AM
gargoyle's Avatar
Could it be the cam adjuster?
  #17
Old 05-30-2014, 07:28 PM
gargoyle's Avatar
Cam adjuster?
bydand
2001-2013 model year XC70
46
10-23-2018 11:11 PM
Incursus
07-09-2015 01:48 AM
brettboze
03-26-2012 06:25 PM
glull
07-17-2008 10:51 PM
Quick Reply: intermittent low oil pressure light.
