" Start Prevented Please Try Again." message
Does it work normal or is the key itself sloppy? If it is sloppy then make sure you insert the key so that it stays straight by itself. if it hangs at 90 degrees then the computer cannot read it.
If it still works good then it might need the antenna ring(Lighted portion) around the ignition switch.
LucasMagnus (10-14-2023)
Switchblade key
Thank you so much, my my key fob has a broken spring, so as long as the key is lined up straight with the fob it works, when it is at a 90 degree it doesn't work. Amen!!!!!!!!!!!!
240freak93
1998-2000 model year V70
12-08-2020 04:28 PM
