'99 v70 glt- bypass ignition key start with push-button starter
Old Dec 8, 2020 | 02:24 PM
240freak93's Avatar
Default '99 v70 glt- bypass ignition key start with push-button starter
Happy to be back in the Volvo game after a few years away with two Toyota Prius's (not much tinkering to be done there). Just bought a 99 v70 glt wagon cheap, totally forgot about the crazy expensive cost of getting a second transponder key made, which apparently might be 25% the cost of the car with programming. I have zero concerns about the car being stolen. Has anyone simply installed a push-button starter somewhere on the dash, then wired it directly to the starter? I'm thinking I could enter the locked car and turn ignition switch to position 1 with just a regular $30 (without the transponder chip ) key cut to my vin number, then engage starter to crank engine using the push button switch. Am I missing something, or is the anti-theft system so sophisticated that the engine won't run doing this to engage starter. I'm just paranoid about only having one key for the car in case I misplace it, and I've seen push button start switches installed on a few old Mercedes diesels. Thanks
Old Dec 8, 2020 | 04:28 PM
Yes you are - the chip in the key deactivates the immobilizer system. If there is not a recognized key present - the car will not start - hence the name - immobilizer.
I have heard - that you can tape a recognized key (with a chip in it) to the bottom of the steering column next to the antenna ring, probably under the plastic cover - then use a non recognized key (your not programmed copy) to turn the ignition and start and drive the car.
Midtown Girl
Dec 18, 2016 11:22 AM
87roadwarrior
Aug 26, 2015 10:26 PM
sven0777
Jul 22, 2013 01:18 PM
rspi
Dec 10, 2011 10:58 PM
Squiggy
Aug 17, 2009 10:29 AM
